Fitting reversing sensors!
Hi all. My wife has complained that when she is reversing the car she can't see the back end. I tried asking her not to drive it... didn't work!
So I have purchased a kit to fit sensors on the rear bumper, it is a wireless kit and can be set to only activate when reverse gear is selected. However, this means I have to wire the device into the correct circuit.
Does anyone know the best place to find the necessary wires, what color they are, and how to connect into them? Has anyone done this before and could help? I tried searching but, maybe I typed the wrong questions as what I found didn't really help?
Thanks in advance for all help :-)
For the ZF transmission on the non supercharged engine you would have to devise a not on these positions switch on with a dampener so it wouldn't turn on as you move through the positions
Or a very low power signal from the illumination LED with a use of a darlington switch to get useful power to switch on you device .
Notice a ground providing enable vs. a power providing enable for your device .
euphonium01 (04-15-2018)
The following 4 users liked this post by avern1:
Lommi
04-19-2018 06:42 AM
