Fuel Pump # 2 not working?
Old Feb 23, 2014 | 10:23 AM
rocklandjag's Avatar
Default Fuel Pump # 2 not working?
My car requires long cranking (2x) when cold but starts right up when warm. Recently I got short RP and then codes 0171 &0174 so I checked both fuel pumps:
-both relays in place - car starts
-remove relay for pump #1 - car cranks but won't start
-switch relay from pump # with pump #2 - still won't start
-Pump #1 jump contacts 3 & 5 - can hear pump running
-Pump #2 jump contacts 3 & 5 - no sound
-fuse #15 is good
Is my pump #2 dead?
thanks
Old Feb 23, 2014 | 01:34 PM
avt007's Avatar
Sounds dead to me, I'll look at the wiring diagrams later day.
Old Feb 23, 2014 | 04:31 PM
avt007's Avatar
I looked at the 98 and 2002 wiring diagrams and I'd say your #2 pump is dead.
Old Feb 24, 2014 | 06:22 AM
plums's Avatar
Originally Posted by rocklandjag
Is my pump #2 dead?
pretty much
the only other possibilities are:
- no +12 at the relay
- wiring between relay and top of tank is bad
- in tank link lead is bad
the third possibility still requires tank removal, so it is effectively the same chore
to discount the first possibility i like to jumper from the power junction stud at the corner of the fuse box
Old Feb 24, 2014 | 06:59 AM
Rob - thanks for checking
Plums - I will voltage at the relay
looks like its time to buy a pair of pumps
Denso, airtex, Cole Haan - lots of choices
Old Feb 24, 2014 | 09:39 AM
motorcarsrandy's Avatar
Ford E150 van..
thatone always cracks me up. The pumps fit many vehicles.
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
alpecsa
Sep 7, 2015 11:55 AM
Sprayall
Sep 3, 2015 07:49 PM
