Fuel return system question
Old Dec 27, 2011 | 07:30 PM
ra.stewart's Avatar
Default Fuel return system question
I have an XK8, but was hoping that the XJ8 might have a very similar system. My question is, is the fuel return line supposed to have any restriction in it? The is a connector in between two pieces of line, but I have not found it, nor do I know if it have any function other than linking the two pieces of line together.
I don't mean to muddy up other forums, but there seems to be little experience in the XK world on this. My car seems to have some restriction in the return line and is driving my fuel pressure way up.
Any and all help/advice is most appreciated!
Old Dec 27, 2011 | 09:06 PM
motorcarman's Avatar
The fuel return line from the pressure regulator goes directly to the tank with no restrictions. It runs under the car on the left side to the tank bottom above the diff.
There is a 'tangle' of fuel lines and heater hoses behind the throttle and maybe a plastic or rubber line is 'kinked'?????
bob gauff
Old Dec 27, 2011 | 10:53 PM
jimlombardi's Avatar
Hi
Look at this new thread about fuel rails with diagram showing fuel supply and fuel return pipe (#6) and fuel return hose (#9):
https://www.jaguarforums.com/forum/x...r-i-faq-65505/
Jim Lombardi
Old Dec 28, 2011 | 07:16 PM
ra.stewart's Avatar
Thank you both for your valuable input. I'll start a careful search from end to end Friday if the weather cooperates. If I can get this last issue settled I can then move on to our MK VII, her new electronic distributor is sitting in the box waiting!
Thanks again!
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
