Full Jaguar EPC Download, with complete install instructions.
Old May 4, 2014 | 02:51 AM
  #81
Bartek's Avatar
Download yourself where you want it.
Bug fixes displaying images - Adobe Flash Player ActiveX.
McAfee Security Scan Plus, macromedia this Offtop.
Old May 4, 2014 | 02:56 AM
  #82
Bartek's Avatar
Look:
Adobe Flash Player - Downloads
under:
Download the Windows Flash Player 13 ActiveX control content debugger (for IE) (EXE, 16.96MB)
and check link:
http://download.macromedia.com/pub/f...3_ax_debug.exe
happy?
Old May 4, 2014 | 02:17 PM
  #83
inlucemedita's Avatar
Originally Posted by Bartek
Sorry,
This is new link: http://download.macromedia.com/pub/f...3_ax_debug.exe
I have latest versions Adobe Flash.
Screen:
This link fixed the images issue for me.
Thanks to all.
Great resource.
Old May 7, 2014 | 07:26 AM
  #84
jimlombardi's Avatar
Yes, I am happy that you found the adobe flash player issue with JEPC.
At least it was not anything wrong with the JEPC software installs.
Thank you for sharing the fix.
Jim Lombardi
Old May 7, 2014 | 06:30 PM
  #85
Beartoy's Avatar
Default Thanks Again for Posting this Item
Thanks so much for sharing this item. I've completed the installation and had no troubles. I've already located three small parts I need for my new project - 2000 XJ8. Any recommendations on USA parts source?
Old Jun 8, 2014 | 01:23 PM
  #86
elia's Avatar
Hi All!
In November, 2013 I downloaded and installed this catalog for one purpose - check car's complectation with VIN. Checking work with manufacturer's DB. But from middle of January up to present time this function not work - https://www.newjepc.unipart.co.uk not response. Do you know how I can check Jaguar's VINs now?
Thanks.
Old Aug 9, 2014 | 09:17 AM
  #87
Partick the Cat's Avatar
Cheers Bartek ! That debugger has solved my invisible pictures problem !
Old Dec 16, 2014 | 07:09 AM
  #88
RJ237's Avatar
Originally Posted by jimlombardi
I decided to put all the folders and files into a single file JEPC download to provide a better method of downloading to a single folder on the hard drive, then moving the downloaded file to the C drive. See instructions below.
Here is the weblink to the updated JEPC:
https://www.dropbox.com/s/jdroz6d0u8m1aql/JEPC.exe
The updated JEPC download folder and file contents:
All that needs to done is to download the updated JEPC archive file (JEPC.exe) to your PC desktop or your PC user id download folder.
Then move the JEPC.exe from (your the folder where you downloaded it to) by cut and paste to your C drive (C:\) or drag it onto your C drive (C:\).
Then run C:\JEPC.exe to extract all the folders and files (the extract will create all the folders and files on the C drive).
Copy the shortcut C Drive JEPC that is now in the C:\ folder to the desktop.
That is all that is needed to complete the install.
The Jeg image above shows the contents of the updated JEPC.exe download file, also has snapshots of the updated JEPC folders and files after the JEPC.exe is run on (from) the C drive.
The Login ID is admin (it does matter if you use lowercase or uppercase) the Login becames uppercase anyway.
The password is 123
Jim Lombardi
I am unable to complete the download. It fails at 38.1 MB. Has anyone else run into this problem?
Old Dec 16, 2014 | 07:58 AM
  #89
The download is working properly.
I just tested the download - took about 2 minutes to finish successfully.
Jim Lombardi
Old Dec 16, 2014 | 08:04 AM
  #90
RJ237's Avatar
Oh well, I can get by without it.
Old Dec 16, 2014 | 08:38 AM
  #91
I sent you for Private message (reply to yours) about diskspace and test your hard drive.
You can use the website - it has most of the same information - jaguarclassicparts.com/uk/jaguar-xj-x308-parts:
Jaguar XJ Series X308 parts | Jaguar Heritage Parts UK
Jim Lombardi
Old Dec 16, 2014 | 09:03 AM
  #92
bdboyle's Avatar
Dealers obviously have a nice markup...if the price list is correct...
Either that, or JLRUSA isn't sourcing their supply chain very well..
Old Dec 17, 2014 | 05:50 AM
  #93
RJ237's Avatar
After trying to download several times I realized the problem was I was using Firefox. I opened Internet Explorer and shut my security off and it took about a minute to download.
Old Jan 13, 2015 | 12:29 PM
  #94
brkcskn's Avatar
First, thank @jimlombardi you have helped me about part pictures. However i have a problem part numbers when i try to find part numbers i cannot find the new part number. Jaguar has been changed old part numbers and my catalog whic is epc 2009 does not show superssions part number. I need to help to find superssions part number.
Old Jan 13, 2015 | 05:25 PM
  #95
Do you means the old part numbers you found in the Jaguar Electronic Catalog (JEPC) is now superceded by a new part number?
Example: Throttle Body for X308 XJ part number in JEPC is LNE1560BA.
I almost always go to gaudin jaguar parts.com website and use their part number search with the part number I found in the JEPC.
The search with LNE1560BA comes up as the old part on their website and it says part number superceded, then gives C2A1445 as the new part number.
Another example: JEPC Part number LNC3030AG is gearbox harness. The search on gaudin website does not say it is superceded by any new part number, so LNC3030AG is still the current part number.
Here is a photo of the part information paper tag attached to the harness (Ebay photo):
Here another Photo of the entire harness:
I think you were asking about the gearbox harness on your 1998 Xk8.
Jim Lombardi
Old Jan 14, 2015 | 10:48 AM
  #96
brkcskn's Avatar
@jimlombardi
Hi Jim, yes i was searching as same as system like gaudin also i found parts.com whic system same as gaudin. I have found my gearbox harness on Germany. In Turkey cars lhd. Also, is there a system for epc whic inclued superssion part numbers?
Last year i had found epc 2013 and it has inclued even F Type! Now, i cannot find EPC2013 and for a while epc 2013 allowed find number and superssions part number by using epc online. However, Jaguar realized the bug and cut it off!
I think someone who has epc online for pc it can upload part numbers folder on the web and we can find easily find part number even it has been changed
Best Regards
Burak
Old Jan 14, 2015 | 01:21 PM
  #97
brkcskn's Avatar
Hi everbody,
I found Jaguar EPC 2013 whic include F Type Parts!
If you want this please send me an p.m. and i will send you torrent download link.
Regards,
Burak
Old Mar 22, 2015 | 01:13 AM
  #98
Mark in Maine's Avatar
I almost paid for this on-line. Thanks soooo much, worked first time up.
Old Apr 14, 2015 | 01:55 PM
  #99
metoymi's Avatar
Wekrico,
Did anyone ever reply to your question? I read through most of these posts but I may have missed someone successfully viewing the EPC on an Apple Mac. I have a 2006 Macbook Pro that is 64 bit. It appears that the download info here is strictly for Windows machines.
Old Sep 2, 2015 | 02:28 PM
  #100
fingers's Avatar
install went well but when trying to login it says im not connected to the internet
