Fuse box layout diagram
Old Sep 6, 2011 | 01:22 PM
XJRJeff's Avatar
Default 99 Relay Locations
Here is a relay layout and the component layout. Looks like the fan relay info is on the component layout. Hope this helps.
File Type: pdf
File Type: pdf
Old Sep 6, 2011 | 01:35 PM
XJRJeff's Avatar
Default exhaust removal
Originally Posted by alexhauber
Anybody have Instructions on how to remove the Exhaust from 2001 XJ8. Seems to be the only way for me to get to the O2 Sensors
Hey Alex,
Your going to want to remove the intermediate muffler in the middle underneath the car. I would call it the cross pipe, both pipes go into one muffler in the middle of the car. Loosen the 4 clamps on that section and your going to have to do some good tugging. Your going to want to remove the two rear connections first and then pull the whole intermediate section off the cats. The cats can be removed from the engine bay with 4 bolts. You may have to remove some heat sheilding to get to the bolts first. You may decide that you can get to the sensors after you remove the intermdiate muffler. It does provide quite a bit of room once it is out of the way. I am going to attach a link to my post about my 99 VDP. If you scroll to the bottom of the posts you will see I have a post with some pictures of the exhaust system. Hope this is helpful.
Old Sep 7, 2011 | 07:19 AM
jimlombardi's Avatar
Hi Alex
I started a new thread for the Heated Oxygen Sensors:
https://www.jaguarforums.com/forum/x...08/#post401807
It has a step by step instructions and illustrations.
Jim Lombardi
Old Sep 18, 2011 | 09:41 PM
wyche1's Avatar
there are 6!
if you don't have them already I find them and add to the forum
Old Sep 19, 2011 | 08:08 AM
Hi
Look at post#4 in the "Drivers control module issues no power" thread. There are 15 pages extracted from JTIS Repair Shop Manual CD showing all the location diagrams and fuse/relays tables.
https://www.jaguarforums.com/forum/x...86/#post376412
Also it is in the XJ8/XJR FAQ quick links sticky thread. Use the Edit/Find in Internet Explorer to search the FAQ thread using the "driver control module" as the search string.
Jim Lombardi
Old Sep 4, 2018 | 08:22 AM
Takeo's Avatar
Default Not really ...
Originally Posted by SuperSport
Pages 4-12 through 4-24
This attached Document was downloaded freely from the Jaguar Website. It is for the 2000 XJ's, but I've yet to find a difference in my 1999 XJR.
It shows the Fuse/Relay Locations, and usages.
If you don't already have it installed, you will need the Free Adobe Reader to open the Document:
Thank you !
My 2001 has under-hood similar fuse boxes, A and B, but different than what you posted in your PDF.
Also, my original owner's manual is wrong too. (french edition, a translation of your PDF, but wrong).
I replaced a 10 amp fuse today, but I have no idea at all what it is for.
Any ideas ?
Thanks,
Takeo.
Old Sep 4, 2018 | 11:22 AM
Jhartz's Avatar
Wow: replying to a seven year old thread. In the sticky section there are latest versions of the wiring diagrams -- there were minor changes between late 1997 models in Europe and last US models in 2003.
Old Mar 26, 2020 | 08:49 AM
  #28
gardenkeeper's Avatar
Most likely a bad brake light switch.
Old May 19, 2021 | 01:51 AM
Corey Prioleau's Avatar
Originally Posted by NorCalDiesel
there are no less than 4-5 fuse boxes/panels, maybe more. Which one are you looking for, or what are you looking to replace.
trying to figure out if the fuse control my window panel
Old May 19, 2021 | 02:53 AM
  #30
M. Stojanovic's Avatar
Fuse #2 in the Left Hand Heelboard Fuse Box.
hamilton7550
Jul 30, 2021 11:29 PM
abonano
25
Sep 25, 2015 10:43 AM
drewlabarbera
Sep 22, 2015 01:54 AM
r111ynf
Sep 20, 2015 09:42 AM
eurotire
Sep 18, 2015 07:27 AM
