gas tank ventilation problem?
Old Jun 10, 2009 | 05:30 PM
chupacabra's Avatar
Default gas tank ventilation problem?
hi everyone as allways I come up with strange problems something is wrong with my gas tank after some driving if I open a gas tank cap the pressure goes out (its quite big pressure, the cap stays in the air for a while) newer happened before. in the JTIS I found out that there is some kind of solenoid under the bonnet that regulates the presure in the tank.... what the hell is that ? is it fixable? where should i look for a problem?
Old Jun 10, 2009 | 06:53 PM
jag_genius's Avatar
i wud check the close valve.. when engine is off this stays open .. relieving pressure so you dont have a pressure build up.. valve is behind differential.. right side.. has to hose off it one to canister a one to air vent
Old Jun 11, 2009 | 05:11 PM
chupacabra's Avatar
ok.... then perhaps the reason could be "gravitex" (I sprayed the botom of the car few weeks ago it's this stonechip thing) I remember those hoses one of them goes to some small black box not far from differential... guess I have to get under the car, if it's posible to somehow damage this walve by sprayng on it then probably it will be the reason..
Thanks for the advise..
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Nov 23, 2015 01:56 PM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
laserguy
Sep 3, 2015 02:02 PM
