General wheel sensor fault on xj 2010 plate
Old Jan 30, 2018 | 01:24 PM
Dusty Millar's Avatar
Default General wheel sensor fault on xj 2010 plate
Sensor fault won't reset, replaced sensors, any ideas
Old Jan 30, 2018 | 02:16 PM
avern1's Avatar
I am not familiar with your year vehicle and most members here probably are not either. The correct section is https://www.jaguarforums.com/forum/xj-x351-53/.
That said you might have to go and have the code cleared. Most auto parts stores offer code reading and clearing free. If it will not clear then you most likely have a bad wire to one of the wheel sensors. If you go to the link above after getting the codes read and post the code numbers someone will be able to tell you which wheel is the problem.
Kaeghl
Apr 26, 2017 08:58 AM
Cat2
Apr 19, 2017 05:45 PM
Adam J
Apr 11, 2017 08:24 AM
shemp
Apr 2, 2017 07:25 PM
GarrinChilders
Jul 21, 2008 10:12 PM
