Groan from the rear upon initial start.
Old Nov 4, 2017 | 02:02 PM
King Charles's Avatar
Default Groan from the rear upon initial start.
When I start the car for the first time of the day I get a low groaning from the driver's side rear, it sounds like a corroded arial antennae going up. I have long ago removed the fuse for my antennae so it's not that.
Any clue from the wise lot here ?!
Old Nov 4, 2017 | 02:14 PM
Sean B's Avatar
can you get a video posted? Guessing could be fuel pump, fuel filler lid release solenoid, creeping on the handbrake....etc....
Old Nov 4, 2017 | 02:17 PM
Yes I'll try but it's sporadic not everyday it occurs.
"handbrake" You know what, the people that inspected my car yesterday had an issue w/ the parking brake it was a girl & she struggled to get it engaged. What can I do to check on this ?!
Old Nov 4, 2017 | 04:16 PM
Jhartz's Avatar
Have you previously heard the fuel pump during start up? Or is this something that only begins when in drive and beginning to move?
I won't bother you about why you haven't fixed the aerial: a simple repair.
Old Nov 4, 2017 | 05:48 PM
Can't recall hearing it before but truthfully my stereo's often on loud seems to be when I'm beginning to move, usually in reverse.
The aerial's in fine order I just disabled it for aesthetics & my upgraded head unit doesn't require it. I'm familiar w/ the sound from an old Infiniti Q45 lol.
Old Nov 4, 2017 | 08:00 PM
ericjansen's Avatar
Vapour recovery system?
Old Nov 4, 2017 | 08:06 PM
Duly noted sir.
Old Nov 14, 2017 | 09:29 PM
So since I posted this thread guess what ? Zero noise from the rear lol.
Old Nov 19, 2017 | 09:09 PM
vdpnyc's Avatar
The fuel pump will SOMETIMES make groaning noise at start up under normal operation and it is located behind the back seats. This is considered normal and not a reason for concern. If you park inside a garage the sound seems noticeably more amplified (and more concerning), but indeed this is normal and not an issue.
