Head Lamp assembly removal XJ8
Old Sep 25, 2010 | 10:43 PM
spuds1956's Avatar
Default Head Lamp assembly removal XJ8
Need some info on the best way to remove my head lamp assembies
from my 99 XJ8 . Want to clean them ( very dirty and cloudy
inside ) and install some HID bulbs.
Old Sep 26, 2010 | 12:15 AM
Dan R's Avatar
Removal is posted on the boards. Remove grill, painted trim and headlight assemblies. Wash with glass cleaner. Not sure about HID, reflectors may not be set up for them. I use Philips Night Guide bulbs, good performance.
Old Oct 1, 2010 | 12:12 AM
jimlombardi's Avatar
Default JTIS extract for Headlamp Assy r&i
Here are the 4 PDF files I created from JTIS information on Headlamp Assembly r&i
1) High beam Headlamp 86.41.34 r&i.pdf
2) Headlamp Assembly 86.41.33 r&i.pdf
3) Radiator Grille 76.55.03 r&i.pdf
4) Radiator Grille Bezel 76.55.15 r&i.pdf
Please Note that the Headlamp Assembly 86.41.33 calls out a section for Headlight Trim Panel 76.11.23
I could not find this section in my JTIS
Old Oct 1, 2010 | 10:23 AM
Sean B's Avatar
Helps if you use a penetrating oil on the nuts nad bolts, and do after the car has come off a run, warm engine compartment, cold plastic breaks easy, I've not seen one without a repair.
You can buy H7 adaptors now for the bulbs - HID install thread on here is excellent, use the search.
Good luck!
Old Oct 20, 2010 | 04:01 PM
wfd's Avatar
wfd
Does anyone have diagram for a 1998 vanden plas fog lamp assembly? My left fog lamp is swinging back and forth. It looks like the bottom adjustable assembly is damaged.
Old Oct 20, 2010 | 06:52 PM
Default 98 XJ8 Front Fog Lamp R&R info
Hello
I extracted the Fog Lamp Remove and Install procedures from my JTIS CD into this PDF. There are 4 pages in this file. The 1st Page gives illustrations and steps to remove the lamp, also calls out the procedure to Remove Splash panel that is on page 3 in this PDF.
Here is the attached PDF file Jaguar XJ8 Front Fog Lamp R&R.pdf
I hope this is what you wanted. If not let me know and I will try to get you the information.
Jim Lombardi
Last edited by jimlombardi; Oct 22, 2010 at 11:53 AM. Reason: missing a word in the second sentence
Old Oct 21, 2010 | 10:15 AM
wfd's Avatar
wfd
Originally Posted by jimlombardi
Hello
I extracted the Fog Lamp Remove and Install procedures from my JTIS CD into this PDF. There 4 pages in this file. The 1st Page gives illustrations and steps to remove the lamp, also calls out the procedure to Remove Splash panel that is on page 3 in this PDF.
Here is the attached PDF file Attachment 5780
Jim Lombardi
Thank you Jim. Just as I suspected, the plastic moulding on the bottom of the fog lamp is damaged.
dsnyder586
Dec 29, 2024 07:39 PM
afterburner1
Dec 16, 2015 12:12 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
Dicque
Sep 4, 2015 12:50 PM
