Head lights problem
Old Oct 22, 2014 | 12:23 AM
Femtech's Avatar
Default Head lights problem
My left side head lamp started flicking of and on while driving sometime time ago, it stopped suddenly but now both lamps on the left side barely glow. When I turn on the high beam both left lamps go out, I checked the relays, the fuses and the module in the trunk, they all seem to be Ok. Any ideas how to solve the problem ?
Old Oct 22, 2014 | 02:17 AM
yarpos's Avatar
It might help if you state the year/model of the car you are talking about, or put it in your signature or fill in a garage entry
Old Oct 22, 2014 | 08:42 AM
RJ237's Avatar
It sounds like a bad ground.
Old Oct 22, 2014 | 09:54 PM
Femtech's Avatar
Default Re: Headlight problems !
I forgot to mention that the car is a 1999 XJR
Old Oct 26, 2014 | 11:53 AM
jhumph21's Avatar
I just bought a '02 XJR myself, and the front headlight already went out on me. Trying to figure out what the problem is....Help please!
Old Oct 26, 2014 | 12:36 PM
Jhartz's Avatar
A bad ground or dirty contacts at the socket for femtech; maybe bad relay for both. Probably a bad bulb for JH 21 in the light that has gone out. The problem with the lights remaining on is likely a broken wire in the multi-switch.
Old Oct 29, 2014 | 10:02 PM
Femtech's Avatar
Default Headlight Problem
I tapped ground from the chassis to the headlamp ground wire, problem solved ! Thanks to JH for the hint.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
