Heat.... Need help....
Old Sep 10, 2018 | 04:37 PM
Curley's Avatar
Default Heat.... Need help....
Hi all.... again, I'm new to owning a real car... I have a 2000 XJ8. with winter coming way too soon for me, I turned on the heater yesterday to make sure it worked and sure enough, no heat! So, wheres the best place to start checking? I really don't want to just start replacing parts without some clue. The coolant is right up to the neck, the AC works great.
Thanks so much
Old Sep 10, 2018 | 05:32 PM
avern1's Avatar
The first step is to set the temp control to HI that will be max heat. Then see if you are getting heat. If you are then press the button for EXT temp. Is it reading close to the actual outside temp.
I couldn't get heat because the external temp sensor showed it was a 132 degrees outside and wouldn't give heat.
Try that and get back to us.
Old Sep 10, 2018 | 06:00 PM
CharlzO's Avatar
Another thing to check - do you have ANY heat at all? max temp, low speed, hi speed, etc? I had an issue with no heat prior, and it was the auxiliary pump located on the drivers side (US) inner fender well, near the brake booster. Usually the brushes will wear out and the motor gives up. Coolant will pass through to keep the engine from overheating, but won't flow properly to diver to the heater core and all that jazz. You can either repair the brushes, or just replace the unit - I opted for replacing with the intent of repairing the original but never bothered since it hasn't acted up in the last 50k miles. Replacing it with another known good unit takes about 10-15 minutes, and CAN be done without removing the coolant expansion tank, just takes some fiddling.
That's if that's what the problem ends up being, of course. I think I spent 40 bucks or so when I got mine used on e-bay? Been a while. I believe it's the same pump that the intercooler pump is for the SC cars, which can be replaced with a nice Bosch unit with a wiring splice, so that might be another option too - though the Bosch is thicker around so the bracket might need help.
Old Sep 10, 2018 | 06:37 PM
Curley's Avatar
Thanks very much.. I just checked the hose going into the pump. The pump is hot and one hose is hot but the other hose is cool. I've got no heat on any fan speed. I think it's the pump.... ???
Old Sep 10, 2018 | 07:45 PM
Highhorse's Avatar
You mean it really wasn't 132 in Vegas Vern?
Old Sep 10, 2018 | 08:27 PM
Dantucker's Avatar
Sounds like the heater pump, the brushes in the pump wear out and the pump quits. I was able to replace the brushes on the pump in my XJ8 and solve the issue. Here is the brushes I used. .15" x .15" x .35" BRUSH 33A
Old Sep 13, 2018 | 04:35 PM
Curley's Avatar
Default Omg... Still no heat
. Today I replaced the water pump for the heater. Topped off the antifreeze and drive the car. Still no heat... Seems like all the hoses are hot but I don't think it's going into the heater core. I'm not real sure about that. What could I be missing?
Old Sep 13, 2018 | 04:43 PM
avern1's Avatar
Surprisingly it never reaches a 100 in December LOL.
Old Sep 13, 2018 | 06:03 PM
Highhorse's Avatar
LMAO!!
scottyg
Jun 15, 2022 12:11 AM
Biff Baxter
Jul 6, 2017 09:44 AM
WinterJag
33
May 13, 2012 10:05 PM
michaem101
May 12, 2010 09:47 AM
e21pilot
Apr 30, 2010 05:52 PM
