Heater not very hot.....
Old Nov 24, 2013 | 08:46 AM
Maninahat98's Avatar
Default Heater not very hot.....
Hi, It's getting colder so only just noticed that the heater doesn't seem to work efficiently. Air con is very cold, works great.
I have read about checking out the heater pump and heater valve and flushing through the matrix etc. My question is....with the one way valves in the system...how much do I have to drain down the heater/cooling system...only just below the level of the electric heater pump, or more? Risk of air locks once refilled? I looked in the manual, doesn't give a procedure for removing the heater pump and valve - I can give it it a good guess...however, so much about these cars is 'specific' and sometimes different to other mark's methods...... I would rather do it the easy way and ask first ratter than the hard way and have to learn by my mistakes and all.... Thanks Allan
Old Nov 24, 2013 | 11:27 AM
test point's Avatar
First thing I would do before disassembling anything is to confirm that the heater circulation pump is operating . . . or not. You should be able to feel it turning on/off with the climate control operation.
jazzman20014
Oct 26, 2015 04:15 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dickc
Sep 21, 2015 02:04 PM
