Hello, new member here, I have a Valet problem
Hello
I have a jaguar xj8 from 1998 and I have a valet problem. None of the recomandations from the previsious suggestions from other threads help me.
I think it's appart from the rest
So, let's begin:
> I have only the black headed key without any remote, I unlock the doors from the key hole with this key. ( when i put it in D to go, the doors lock automaticly)
> when I'm in the car with it running and press the trunk open button, it says VALET MODE
> when I try to open the trunk with the key it won;t let my. It turns a little but no efect
> when i push the button from the trunk to open it, a sound from inside sounds, and at the board appers VALET MODE.
It is an unique problem I think, I tried some methods up but none describes my case exactly.
Please, any suggestions are welcomed as winter comes in my country and I don't want to get stranded with my battery dead and with my trunk unopened.
THANK YOU!!!
So, let's begin:
THANK YOU!!!
When you put the key in the lock it should rotate a full 90 deg. and the lock should release. If it doesn't do so the lock needs cleaning. Squirting penetrating oil in the keyhole and working the key should loosen it.
If the black key will open the trunk after spraying it with the WD-40 then it is possible that the valet button is stuck. You might try spraying it with electronic cleaner and pressing it many times to free it up. It is similar to the sticking problem of the Hazard switch.
The valet mode should automatically shut off once the vehicle is started with the proper key.
First, stop pushing the dang valet mode button - that is making your issue worse. If you have only the black key then you cannot use valet mode anyway (you need the green-key to lock-out valets from your trunk).
I had both keys and shaved down my green to work like a 2nd black one because valet mode is of no use to me.
If you are in valet mode then the black key is the ONLY way to enter your trunk, aside from drilling a hole underneath the license plate to manually access the release cable.
Valet mode in my car ONLY deactivates when you open the trunk using the black key. Nothing else shuts it off, not starting the car with the black key, nothing. Presumably, if you disconnect the battery for 30+ seconds it will disable the mode but the battery is in the trunk, so that does not help you, lol, and it is possible that the SLCM (security module) saves the valet mode setting through a battery disconnect anyway.
You need to find a way to make your black key turn in your trunk lock.
Once you do that, all the electronic trunk access will start working too (button on trunk lid, in car, on the remote fob if you get one and program it to your car, etc.)
FYI, in the trunk it turns 90-degrees in the clockwise direction (turning away from the license plate)
Thanks a lot guys !!!!
WOW...didn't see that coming so fast. WD-40 is an amazing spray
I opened my boot today after spraying some wd40 in there. OK, problem solved...
Now, when for example i,m in p position and my engine is running, when i press the open boot button, it still says on the board valet mode. ?
and the second question is, can i make the car's phone, that motorola that is still woring, get some nowadays signal? with a sim card or something? maybe just as a emision reception device ?
THX
))I opened my boot today after spraying some wd40 in there. OK, problem solved...
THX
I believe the stock phone isn't supported anymore by any current carriers, though some people may have found a way to work around that and use the stock phone wiring with newer phone systems?
I think what most usually do is wire in an aux input and plug a bluetooth transmitter into that to set up a hands-free system, but that's basically separate from the factory phone.
THX
THX
If that doesn't do it, try disconnecting the battery for a full minute (called a hard reset) - I'm not sure that will disable valet mode, but it's the next easiest thing to do.
If that doesn't turn it off, you'll need to take apart the inside of your trunk/boot and find the electronic sensor for the trunk lock and figure out why it's not deactivating.
The car phone is analog and thus useless in today's digital cellphone times. It's also illegal for the driver to use while driving in most of the world.
check post #3 - Motorcarman knows his stuff.
Thanks guys, you really helped me, in my country there is no such thing as a jaguar forum or club, very hard to find someone who knows something about the car( technically speaking)
Another question...
In the odometer while I am driving or when my engine is on, a notice appears with a red light near that says: Drivers door open
even if my door is closed. Untill I get this fix, I don't know when exactly, can I do something ( does taking off the battery contact) to cancel and not show anymore this error, I really wanna see other data there as my mileage and so
THANKS !
Another question...
THANKS !
This thread should give you some insight on cancelling valet mode. https://www.jaguarforums.com/forum/x...99-xj8-112231/
Which reminds me, I should really do something about mine...
I just replaced another boot lid latch switch TODAY on a 1997 XJ6. The switches are the same for the X300 and X308.
The customer complained that the boot lamps were inop. The switch failed.
You can 'short' the wires together to check if the circuit is good. If NOT then it is likely the harness damaged at the right lid hinge.
bob
bob
bob
bob
bob
bob
If you unplug the microswitch harness inside the trunk lid and leave it disconnected does the message stay or ever come back? If it does then it's a short in other wiring or an issue with whichever module the microswitch goes to, SLCM? If it goes away completely then I'd guess your new microswitch is bad.
You can remove the switch from the latch assy and 'flick' it several times to watch the lamp reaction for delay verification.
I had this fault on several cars and tried to spray the switch to clean the contacts (no change).
You need to diagnose the problem before you replace parts.
bob
bob
