HELP!! Hood won't open
Old Jun 3, 2009 | 06:21 PM
Markus's Avatar
Identical issue, with multiple responses, posted here: http://tinyurl.com/ordfys
It does not look like a simple solution is at hand, but there it is! Good luck.
________
1999 XJR
Old Nov 3, 2015 | 03:47 PM
kfmif's Avatar
Default same issue here.
anyone? 2001 xjr.
hood pops. but only on the passenger side.
Old Nov 4, 2015 | 06:15 AM
sparkenzap's Avatar
Look in the archives. You have two choices. Remove the hinges or drill a hole in the wheel well and use a screwdriver to pop open the latch. Each is a small PITA.
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
BadKat174
May 26, 2023 12:29 AM
Bc xj
Sep 17, 2015 06:34 PM
