Help! Transmission fault
Old Feb 3, 2014 | 11:03 PM
Kolby11's Avatar
Default Help! Transmission fault
Hi everyone I have a 99 xj8 with 87,XXX miles on it. The problem I am having is when you go into reverse it acts fine then you put it in drive and it acts like its in neutral and if you rev it past about 1500 rpm it jerks really hard and goes into transmission fault mode and has low power and no gears. Please help!!
Old Feb 4, 2014 | 03:18 AM
Sean B's Avatar
Welcome Kolby - it's a shame you have to report this as your first post, but it really sounds like a transmission failure.
If you didn't know there's a very well known and common weak link with this trans - it's a circlip failure leading to the A drum getting damaged.
The latest development attributed to the failure is a worn valve block creating pressure spikes, leading to the failure of a little part that takes out the A drum.
I can only suggest finding a trans specialist in your area and talk to them about a repair or replacement.
Plenty of info about this particular issue, lots of repair posts, you're not alone.
Old Feb 4, 2014 | 03:32 AM
Zorasmiles's Avatar
Sean beat me to it...I was going to guess you were having a transmission failure. Good luck
Old Feb 4, 2014 | 03:54 AM
Welcome to the forum Kolby11,
I've expanded your thread title to add some detail. Sorry to hear you've got transmission issues.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 4, 2014 | 06:41 AM
OldMike's Avatar
Very similar issue with mine a few months back - I got a rebuilt transmission installed for about $1,700 -- money well-spent, in my opinion. Call around to the various "foreign car" shops in the area to find a transmission shop that is familiar with the problems mentioned in the other posts. Some shops will simply quote you a full rebuild price, which might be worth it, too.
Good luck.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
picard
Oct 12, 2015 11:56 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
tonyforman
Sep 10, 2015 07:23 PM
