Helpful hint if replacing headliner
Old Aug 30, 2021 | 05:30 PM
pcolapacker's Avatar
Default Helpful hint if replacing headliner
Replaced my headliner today. I’m guessing most cars are like mine and the rounded triangular trim pieces around where the visor screws in are either missing or cracked. I had the shop just cut a hole wide enough to pass the wire.
Old Sep 9, 2021 | 01:46 AM
Vonnslingo's Avatar
Hello how did you get it in the car?did it fold? And go in back door?
Old Sep 9, 2021 | 06:04 AM
I used a trim shop. Didn’t watch. Said would go thru back door when I asked about rear window method in the manual.
Old Sep 13, 2021 | 11:33 AM
iwillfixit's Avatar
Often shops take out the rear window in order to replace the headliner.
If you slide the front seats all the way back, you can insert the headliner slightly folded thru the rear doors.
Old Sep 13, 2021 | 11:46 AM
Vonnslingo's Avatar
Is there after market headliners replacements? What are the prices of just the headliners? The installation would be the expense I would think?
Old Sep 15, 2021 | 01:41 AM
Vauxi's Avatar
I replaced headliner of my car. Bought it from Myrtle UK. That folded easily as claimed. Old one falled to peaces when folded. When folded it went in quite easily from back door.
Old Sep 16, 2021 | 05:19 PM
brian2891's Avatar
When it comes to headliners, you can replace the headliner using any foam backed fabric you want. I chose to go with suede instead of the factory type material when I replaced mine. I paid around $50 for 85" x 60" roll of headliner material and maybe another $30 for two cans of 3M headliner adhesive spray and did it myself. It's quite easy. I used the fold and remove/reinstall through the rear doors with the front seats reclined method to get the headliner in and out of the car.
Old Sep 17, 2021 | 08:12 PM
Vonnslingo's Avatar
In your case did you re-cover your headliner or put a new one in it? It sounds like you took the old one out laid it down and then put new material on it and reinstalled it if so that would be a cheap way to do it
Old Sep 21, 2021 | 02:36 PM
jeff xj8's Avatar
Thanks fellas, this job is on my to do list. You answered my questions before I could ask them.
One thing, where does one purchase the fabric? , from a regular fabric / sewing supply place or an automotive type place?
Brian, can you elaborate on "any foam backed fabric". Is it that simple?
Thanks, Jeffxj8
TexasTraveler
Oct 11, 2022 12:19 PM
graham11
Jul 1, 2017 11:02 AM
prettybluefin
Apr 30, 2017 01:36 PM
Rufus T. Firefly
May 2, 2014 02:27 PM
hennebear
Jul 27, 2007 01:08 AM
