Horn Problem '03 XJ8
Old Jun 21, 2011 | 08:36 PM
lowride's Avatar
Default Horn Problem '03 XJ8
Help; I have a problem with the horn blowing when it wants to. I first noticed it when accelerating from a stop (I thought someone was blowing their horn at me). It doesn't do it every time but seems to be more predominant when the car is warmed up a bit. It will just toot a little toot during acceleration (not necessarily hard acceration, just normal driving). Needless to say I am eventually gonna P.O. someone. No other controls seem to be affected (ie. cruise control). Has anyone run into a similar situation and if so how did you cure it? Thanks for any help you can share.
Old Jun 22, 2011 | 03:24 AM
QuadManiac's Avatar
Remove the horn relay and see if it stops... if it does, replace the horn relay and see if it stays away - if so, good...
If not, then it's just about got to be a faulty horn switch in the steering wheel,
OR the Green/blue stripe wire from steering column to BPM that's chafed and shorting to body intermittently,
OR same (chafed, shorting to body) with the Green/white stripe wire between the BPM and the horn relay.
Last, least likely would be a bad BPM.
Old Jun 22, 2011 | 06:25 AM
lowride's Avatar
Default horn
Thanks, Sounds easy enough to try the relay. But I hate to ask but what's a BPM?
dsnyder586
Dec 29, 2024 07:39 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
