How do I remove the coolant pipes?
Old Jul 24, 2021 | 06:42 AM
asjdhsajhdfj's Avatar
Default How do I remove the coolant pipes?
Don’t want to break it so I thought I’d ask before forcing it out
removing as I’ve found out they’re in the wrong place
Old Jul 24, 2021 | 09:01 AM
motorcarman's Avatar
Jaguar issued TSBs for all sorts of info.
Old Jul 24, 2021 | 09:24 AM
thank you - I'll check if the part is hidden in the car somewhere, else I'll use two screwdrivers
Old Jul 24, 2021 | 11:53 AM
Jhartz's Avatar
You can also use needle nose pliers to separate the hold down; water pump pliers, squeezing 90* off those separation points will also open the fitting.
Yes, those hoses are not connected correctly.
Old Jul 24, 2021 | 05:58 PM
xalty's Avatar
squeeze the two round parts
alanroberts50
May 18, 2021 02:44 PM
OnlySlightlyEvil
Jan 11, 2021 01:42 PM
Ikemen
XF (X260)
Nov 9, 2020 06:18 PM
supermop2000
Dec 14, 2019 01:33 PM
nsl1
Nov 27, 2015 10:55 AM
