How do you get the wood trim off around...
Old Jul 10, 2013 | 10:49 PM
Brettl's Avatar
Default How do you get the wood trim off around...
the 3 gauge cluster above the steering wheel ( where the speedo is )? I have purchased chrome rings I want to install them and the seller said to remove the wood and I am not sure how to do it.
Thank You
Old Jul 11, 2013 | 07:22 AM
Donzi's Avatar
Just gently pull it off from the outside edges. Should be able to use just your hands.
Old Jul 11, 2013 | 10:27 AM
danielsand's Avatar
Lower the steering wheel all the way down, tach and fuel opening has a "ledge" (the trim is not even with the instrument cluster). You can feel this ledge with your finger, and you will understand. Place your thumbs on that ledge (at the bottom), and gently pull outward. Pull EVENLY on both sides at the same time. The wood trim will come off. When you are about to put it back, a dab of vaseline on the grommets, will make it slide in much easier, and ease the removal in the future.
Old Jul 11, 2013 | 11:39 AM
WaterDragon's Avatar
I should add that there are compressible steel clips that hold it in place. You will see after you have removed it.
Just pull evenly and it will come out, not for the feint of heart
Old Jul 11, 2013 | 08:50 PM
smtguy's Avatar
Actually it is not the burl wood that you are pulling on. The wood is laminated to some metalization of some kind that gives it rigidity.
No big deal after you do it the first time. Follow Danial's directions to put the steering column down first.
Old Jul 11, 2013 | 10:06 PM
Brettl's Avatar
Success! thank you for the help.
Odd though it seemed that a few clips were not in the top slots. Where can one get more of the meatl clips?
Old Jul 12, 2013 | 07:50 AM
Donzi's Avatar
Mine was that way too, I am not sure that there is supposed to be a clip in each slot.
Maybe make it quite difficult to remove if not impossible if there was.
n8ertot
Oct 11, 2015 02:28 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
