How to Mount Skid Plate to Bumper Cover with Missing Tabs?
Old Jul 11, 2011 | 11:57 PM
OGee's Avatar
Default How to Mount Skid Plate to Bumper Cover with Missing Tabs?
My 1998 VDP came with no skid plate. I guess the previous owner had a serious "nose meets ground" incident. Does anyone have experience mounting a skid plate to a bumper cover that has all the mounting tabs missing?
Old Jul 12, 2011 | 08:05 AM
Blackbeard's Avatar
Smile Well...
The one on my current car (before I fixed it right) and on my old Jaguar, they drilled holes in the bumper then attached the skid plate with plastic wire ties.
Old Jul 12, 2011 | 08:29 AM
Brutal's Avatar
Yes you drill holes in the bumper and through the black tabs that extend over the inside of the bumper. Then i like to use the factory black push pin retainers. I did mine like this 11 yrs ago when i bought it and theyre still there holding tight and look factory
Old Jul 12, 2011 | 02:49 PM
OGee's Avatar
Do you have a part number and/or source for the "factory black puch pin retainers"?
Old Jul 12, 2011 | 03:55 PM
Sean B's Avatar
I think Brutal is referring to the push pins that fix the splash guards on the inside of the front wings, maybe a call to your nearest agent, they'll only be cheap, you'll need to pop the front bumper off for an easier install.
Old Jul 12, 2011 | 05:58 PM
Brutal's Avatar
XR8 8883 you need about 12-15 and drill a 1/4" hole and no you dont remove the bumper. it just needs to be in the air to work underneath
H20boy
Dec 24, 2024 03:23 PM
afterburner1
Dec 16, 2015 12:12 AM
tberg
Sep 7, 2015 07:32 AM
avern1
Sep 6, 2015 04:22 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
