How to verify an Nikasil engine was replaced by Jaguar
Old Jun 6, 2012 | 11:08 AM
sbreeden's Avatar
Default How to verify an Nikasil engine was replaced by Jaguar
I want to know if my 1998 XJR engine was every replace by Jaguar. How do I confirm that is was or not.
On Carfax it shows the throttle body was, but no mention of the engine.
SGB
Old Jun 6, 2012 | 11:59 AM
Sean B's Avatar
either contact Jaguar, or look on the rhs of the engine where the cylinder head meets the block, if it's a replacement, it'll have a green tab there.
Old Jun 6, 2012 | 12:08 PM
Brutal's Avatar
And all the ones i ever replaced had grey painted oil pans. And just because its a nikasil engine, does not meen its bad.
Old Jun 6, 2012 | 12:52 PM
XJR-0220's Avatar
A well taken care of nikasil block is stronger, lighter, has less friction, and produces more power over any lined motor theres a reason they are used still today in cars such as twin turbo porshe, ferrari, lambo, among most of the motorsports. the main problem was with high sulfur content but thts a thing of the past. theres a reason you hve to use diamond coated tools to bore out a nikasil block only thing hard enough to do it
Old Jun 7, 2012 | 07:28 AM
sbreeden's Avatar
I feel much better now, all I read is how bad it was and it will eventually give out. With it low mileage, I would like to keep it for awhile. My last car had 286K and was still going until it was totalled. I would like to have the same result with this car too.
Thanks.
SGB
Old Jun 7, 2012 | 01:24 PM
XJR-0220's Avatar
if it makes u feel better have jag do their test on it to see how its running mine was a very low mileage car it sat through the bad years of high sulfur i had it tested when i got it and it was running better numbers than I have seen on alot of new engines. I dont burn any oil, great power, starts right up, nothing out of the breathers and its leak down numbers were amazing.
fast40driver
Apr 19, 2024 07:24 AM
rusty37
Jun 7, 2016 04:43 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
celticpiping
Sep 18, 2015 06:17 PM
dpappyp
Aug 27, 2015 06:31 AM
