I broke it!!
Old Feb 3, 2012 | 12:00 PM
Heliwilly's Avatar
Default I broke it!!
I was just leaning across the engine at the front to try and locate the engine number and I inadvertently leant on one of the small pipes that cross the engine from front to back, and managed to snap off the connector that goes into the radiator header. What's the official name of this part. I called it, and myself a few, but doubt if the parts guy would recognise the part by these names. Thanks for your help Bill W.
Old Feb 3, 2012 | 01:36 PM
rverginia's Avatar
Picture is worth a thousand words. You may also want to mention what kind of car it is.
Old Feb 3, 2012 | 02:57 PM
Dantucker's Avatar
It is called a coolant reservoir hose, If it an XJ8 you can get them from autoparts wharehouse. http://www.autopartswarehouse.com/se...%26+Components)
Old Feb 3, 2012 | 03:25 PM
Stu 1986's Avatar
Seeing as you are in the UK try Black country Jaguar or Britishparts.co.uk they are good companies. These bits are brittle at the best of times, so don't worry.
The TD5 Land Rover Engine has the same connectors on if you want to do a little digging
Old Jul 1, 2012 | 02:04 PM
Svengali's Avatar
Good luck with repair.
Poet
Feb 7, 2025 02:18 PM
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
04Xjrsteve
May 7, 2019 04:06 PM
adam699
Oct 13, 2015 05:53 PM
JungleJonny
Oct 5, 2015 03:52 PM
