I broke it!!
Old 02-03-2012, 12:00 PM
Heliwilly's Avatar
Default I broke it!!
I was just leaning across the engine at the front to try and locate the engine number and I inadvertently leant on one of the small pipes that cross the engine from front to back, and managed to snap off the connector that goes into the radiator header. What's the official name of this part. I called it, and myself a few, but doubt if the parts guy would recognise the part by these names. Thanks for your help Bill W.
Old 02-03-2012, 01:36 PM
rverginia's Avatar
Picture is worth a thousand words. You may also want to mention what kind of car it is.
Old 02-03-2012, 02:57 PM
Dantucker's Avatar
It is called a coolant reservoir hose, If it an XJ8 you can get them from autoparts wharehouse. http://www.autopartswarehouse.com/se...%26+Components)
Old 02-03-2012, 03:25 PM
Stu 1986's Avatar
Seeing as you are in the UK try Black country Jaguar or Britishparts.co.uk they are good companies. These bits are brittle at the best of times, so don't worry.
The TD5 Land Rover Engine has the same connectors on if you want to do a little digging
Old 07-01-2012, 02:04 PM
Svengali's Avatar
Good luck with repair.
Poet
06-07-2019 07:54 PM
04Xjrsteve
05-07-2019 04:06 PM
1983turbojaguarxj6
02-07-2019 07:23 PM
adam699
10-13-2015 05:53 PM
JungleJonny
10-05-2015 03:52 PM
Quick Reply: I broke it!!
