IDS V118.5 anyone?
Old Jun 5, 2017 | 02:19 PM
Tombloke's Avatar
Default IDS V118.5 anyone?
Hi - I'm looking to get hold of a copy of IDS V118.5
Anybody got a link, or willing to put an iso onto a share drive?
Trying to find diagnostic software to work on a 2000MY XJR seems nigh on impossible.
Cheers,
Tom
Old Jun 5, 2017 | 03:10 PM
motorcarman's Avatar
You will need a VCM (a common J2534 device will NOT work with IDS, only SDD version 125 onward)
Do you have an older Win XP 32 bit laptop?
bob
Old Jun 6, 2017 | 05:52 AM
Tombloke's Avatar
Hi Bob,
Thanks for the reply. Yes I've got old laptops coming out of my ears, so no problem there. I've just lost out on an auction for a full WDS system, which is a bit frustrating, so now I'm looking to make up a VCM solution.
I'm a bit confused as the market seems to be flooded with VCM"2" units. Are these compatible, or do I need to keep looking for an original VCM?
Then I'll use the old software 118.5, or maybe 125.03.
All I want to do is clear/investigate this pesky lambda sensor fault (P1647) which remains even though I've changed the sensor twice and swapped left for right. I suspect a faulty engine ECU, but the replacement I have has the wrong CATS code so I can't just swap it over.
Old Jun 6, 2017 | 09:17 AM
When you swap an ECM to the car you will need to perform an IMMOBILIZATION SETUP.
There can be only one ECM configured to the car at a time. If you install the original ECM back into the car after installing another, you need to configure it back the car AGAIN.
I don't think the VCM2 will be compatible.
bob
Old Jun 7, 2017 | 06:34 AM
JagV8's Avatar
I gather P1647 is a heater circuit fault so have you checked fuses, wiring, connectors etc all the way from the PCM? Such a fault is not very likely to be a bad PCM.
