If My Fuel Pump Has Failed Wont I Get a Code or something?
Old Oct 6, 2013 | 03:55 PM
62sunbeam's Avatar
Default If My Fuel Pump Has Failed Wont I Get a Code or something?
If my fuel pump has failed wont I get a check engine light or something indicating low fuel pressure?
Eric
Old Oct 6, 2013 | 05:36 PM
sparkenzap's Avatar
No! If you had a failing fuel pump, you MIGHT get a lean run engine code, but there is no fuel pressure sensor to tell the ecu that pressure has failed. There is, however, a good test port on the X-308 to measure the pressure with a test gauge.
Old Oct 6, 2013 | 09:07 PM
guyslp's Avatar
I can confirm that, shocking as it is, no code is thrown when a fuel pump fails.
I was cruising along at 60 MPH on a country road when, suddenly - pfffffft - I applied the accelerator and had no power and coasted to a stop. I carry an OBD-II code reader with me and there were none.
It was only after ruling out a wide number of other possible causes for "sudden engine stop" syndrome that it was determined to be fuel starvation secondary to a dead fuel pump.
Old Oct 6, 2013 | 10:08 PM
62sunbeam's Avatar
Thanks guys
A new pump and filter are in and my cat is purring again.
Eric
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Kmw
Sep 8, 2015 04:52 PM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
