inner tie rod 1998 xj8?
Old Mar 8, 2012 | 06:08 PM
jimlombardi's Avatar
Hi
Here is the weblink to the inner tierod ends thread:
https://www.jaguarforums.com/forum/x...ie-rods-64698/
Look at post# 11
Jim Lombardi
Old Apr 13, 2012 | 11:34 AM
Muddybear's Avatar
Yes, you can replace just the inner tie rod, but it can be a little difficult if you don't have the proper tools. You should also check to see if there are any other worn parts because they should be changed at the same time since you will be needing an alignment after replacement of the Tie rod.
Poet
Feb 7, 2025 02:18 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
donald ebanks
Sep 30, 2015 07:08 PM
Woznaldo
Sep 26, 2015 11:02 AM
