Interesting problem with 02 XJR
Old Nov 16, 2014 | 11:33 PM
Mark SF's Avatar
Default Interesting problem with 02 XJR
I was finishing up after changing the water pump yesterday, when I watched a big shiny black widow run down the windshield, across the scuttle, and disappear into the area around the throttle body. Now the damn thing is lurking down there.
I keep getting EGR codes, so I was planning to take the throttle body out soon! How do I make isure it's safe to work on?
Old Nov 17, 2014 | 06:14 AM
RJ237's Avatar
I thought black widows were small.
Old Nov 17, 2014 | 08:43 AM
Mark SF's Avatar
Yes, I should qualify that - big for a black widow. Maybe 1" with the legs.
Old Nov 17, 2014 | 09:30 AM
JimmyL's Avatar
Gloves and lots of bug spray !
Old Nov 17, 2014 | 05:29 PM
ericjansen's Avatar
Time to ask the wife to help you for a while
Old Nov 17, 2014 | 05:51 PM
Mark SF's Avatar
Not much chance of that, she knows about the spider. In fact I think she might boycott the garage altogether!
Old Nov 17, 2014 | 06:09 PM
mcm97's Avatar
this involves a black widow spider? below is the only way you handle this situation
Old Nov 22, 2014 | 10:28 PM
capitaineInsano's Avatar
Talstar is a non-flammable aeresol pesticide. You can probably call the company to ask about temperature restrictions.
Old Nov 23, 2014 | 05:30 AM
andrew lowe's Avatar
You need one of them spider vacuums, or just use an ordinary vacuum cleaner.
Be a bit careful when empting it though.
Old Nov 23, 2014 | 11:28 AM
larney's Avatar
Start the car let it run for 30 minutes or so. The heat should kill it. I would think.
Old Nov 23, 2014 | 01:12 PM
Jhartz's Avatar
Wife is an expert in California black widows having managed an apartment complex in Sacramento. She says the bug will find a place cool enough to survive even if the car is running you can't get rid of them. Bug spray. Maybe garage too. See thread on removing smoke smell in the car. Bug sprays stinks.
Forcedair1
Sep 8, 2025 01:57 PM
allenman85
May 10, 2021 03:11 PM
David Thompson
Sep 3, 2015 07:48 PM
dcvickers
Sep 2, 2015 06:14 PM
