Interior lights - where is the door switch?
Old May 20, 2013 | 05:49 PM
Neil B.'s Avatar
Default Interior lights - where is the door switch?
Well thanks to all those who welcomed me into the fold.
Have a bit of a problem with the xj8' curtesy lights coming on and off when driving. Had a lot of rain recently and wondered if water has got into something somwhere??? And where is the door switch for the interior/curtesy lights??. Be greatly appreceiated if any one has an answer.Thanks. Neil B. XJ8
Old May 20, 2013 | 05:57 PM
Neil,
I've moved your question from New Member Area - Intro a MUST section to the X308 section. Members here with the same model will be able to help with the interior lights issue.
Old May 22, 2013 | 05:37 PM
The schematic for the interior lights may help here:
The lights are controlled by the BPM (Body Processor Module), individual Door Modules and Door Switches.
Intermittent operation with the doors closed suggests a short in the harness or a switch fault. Can anyone confirm whether the switches are part of the Door Latch assembly?
Attached Thumbnails Interior lights - where is the door switch?-x308-1999-interior-lighting.jpg
Old May 23, 2013 | 12:17 AM
jimlombardi's Avatar
Here is a photo of the driver front door lock actuator - door microswitch is part of it - wires are attached to the microswitch (click on photo image to see larger image):
Interior lights - where is the door switch?-xj-x308-photo-front-driver-door-latch-actuator.jpg
JTIS instructions/illustrations on r&r driver door latch (lock actuator):
https://www.dropbox.com/s/cj1ho6la66...74%20R%26I.pdf
https://www.dropbox.com/s/z7t6drcmh8...2076.34.01.pdf
https://www.dropbox.com/s/bvixuhw0of...2076.34.22.pdf
https://www.dropbox.com/s/zbjg4sl9v0...2076.47.11.pdf
Look at this other forum thread - post# 1:
https://www.jaguarforums.com/forum/x...olution-53455/
and (post# 2) in this thread:
https://www.jaguarforums.com/forum/x...ts-work-47379/
Jim Lombardi
Old Apr 27, 2020 | 05:54 PM
Robert Michael Purington's Avatar
Where can you get parts for door lock actuator or switches? Mine looks like VDO VT-ZV SCH 0133.6. Not in VDO website. Not anywhere I can find?
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
XJsc-guy
Nov 23, 2015 01:56 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
