J-Gate 4th gear selector position
Old Aug 29, 2014 | 12:40 PM
Lugnutty's Avatar
Default J-Gate 4th gear selector position
On my '98 XJR, when I move the shifter from D to 4, nothing happens. The 4 doesn't light up and the car doesn't shift. If I push the shifter up toward the 3, I can find where 4 lights up and it shifts, but it doesn't do it right in the corner, on the detent where it should be.
Is this adjustable? Something out of whack?
Old Aug 29, 2014 | 02:19 PM
JagV8's Avatar
Shifter cable sounds to need adjustment.
Old Aug 30, 2014 | 03:47 AM
ericjansen's Avatar
There are several micro switches under the shift-cover, and although I am not sure, I think one is related to the 4-3-2 position of the shifter.
It is actuated from underneath by the circular (and moving around by means of the shifter) inside cover (the one with the brushes).
You might check if this is related, surely someone will chime in on this.
flyrr100
Mar 14, 2016 06:37 AM
knightofgold
Feb 11, 2016 06:03 PM
user 652867429824
Oct 28, 2015 10:18 AM
swetnK
Sep 23, 2015 10:49 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
