J-Gate Problem Again - RESOLVED
Old Sep 22, 2017 | 07:52 AM
jrb53's Avatar
Question J-Gate Problem Again - RESOLVED
hi all 2000 x308 wife's car. have in J gate problem again car will not start unless I move the micro switch going to replace it with another one form a junk yard find not a big deal to remove center consul . so my question is why dose this keep happening this will be the third one I have put in, any thoughts would be appreciated jrb53
Old Sep 23, 2017 | 07:56 AM
Highhorse's Avatar
It simply could be bad luck, but be sure to check the alignment at the contact point, that it isn't pressing (or hitting it) too hard and breaking it.
Old Sep 24, 2017 | 10:10 PM
Addicted2boost's Avatar
If memory serves me correct, can't you take the micro switch from the 'N' and put it in place of the 'P'?
Old Sep 25, 2017 | 04:05 AM
Stu 1986's Avatar
Check the little arm on the switch isn't bent too far outward, the gear stick shaft could be catching them as it passes. This happened on one of my old XJ's on the N switch.
Old Sep 26, 2017 | 06:03 AM
jrb53's Avatar
Thumbs up J Gate problem resolved
thanks to all problem solved. turn out to be bent micro switch. replaced it with one from the old one that I had saved. good job I am a pack rat as I have a lot of old parts. thanks again to forum members jrb53
Old Sep 26, 2017 | 10:52 PM
Don B's Avatar
Hi jrb53,
Congratulations on successfully solving the problem. I have merged your post about the resolution with your original thread about the problem and marked it RESOLVED so future readers will be able to see the entire account.
Cheers,
Don
Old Sep 27, 2017 | 03:49 AM
Stu 1986's Avatar
I'm glad you got it sorted, bent switches are a common problem on these I think. I'm like you, I keep a lot of spare parts in stock which I'm always adding to. I'm going to have to build special storage in my attic I think as I've run out of room in my garage. LOL
tmwsccsh
Aug 18, 2020 09:10 AM
M003thomas
Sep 28, 2017 06:03 PM
aholbro1
Sep 24, 2017 06:03 PM
Martin Dixon
XF (X260)
Sep 6, 2017 10:07 AM
slmskrs
Sep 2, 2017 08:33 PM
