Jaguar xj8 transmission fluid drain
Old May 11, 2017 | 08:48 PM
Raymondo the Unbelievable's Avatar
Default Jaguar xj8 transmission fluid drain
Hi Yáll
I read in a forum that you can drain more fluid from the ZF 5HP24 auto transmission if you disconnect the return hose from the fluid cooler.
I believe the return hose is best disconnected where it enters the transmission.
My question is, which hose is it? Do you know which size tool is used?
Old May 11, 2017 | 08:57 PM
King Charles's Avatar
http://www.bmwe34.net/E34main/Mainte...0Autotrans.pdf
AHB900
Oct 12, 2016 12:19 PM
JagBenny
Oct 7, 2016 10:06 AM
Cee Jay
Oct 3, 2016 08:28 PM
Sep 25, 2006 10:38 PM
Nov 8, 2005 02:14 PM
