jaguar xjr 4.0 supercharged wont start
Old Jun 13, 2012 | 04:12 PM
jamiecap's Avatar
Default jaguar xjr 4.0 supercharged wont start
hello guys im new to this but here goes
i have a jaguar xjr 4.2 supercharged.
i had it stood for 3 years as i brought a new jag, i came to start it about 15 months ago and it was just turning over not fireing. but it was sparking as i squirted minimal amount of easy start so i new it was fireing,
then i left it for another year didnt try to start it just straight away i had the tank out and fuel pumps cleaned 1 of the pipes had come off top of fuel pump, so i assumed this was problem, put it all back together , come to start it and nothing not even clicking, ignition comes on, i had vault tested on starter and no power there either.
also wiper dont work squirter s dont work lights dont work, i have engine check light on and another light but i dont no what it is a bit like a bulb with a line through it,
so i dont no if ive done something wrong or if it was like this before i even took tank out., i wish i had tried it again before i pulled the tank out.,
im baffled on this 1 out of ideas i hope its not time for scrap yard,
just a update with my valult stick i have traced power to the starter motor, so should i pop this off clean it and test it, i took the earth cable off cleaned t but still nothing
appreciate any replies thanx jami
Old Jun 13, 2012 | 08:47 PM
sbreeden's Avatar
1st, four years of no charging, it time for a new battery.
2nd, how fresh in the fuel?
3rd, Air filter clean?
4th, Check to see if anything, made a nest in the exhaust.
All of the above needs to be checked and corrected for a car that sits that long.
Don't send it off to the salvage yard, if you get tired of part it out. You get more for parts than the yard will ever give you.
Old Jun 14, 2012 | 01:52 PM
jamiecap's Avatar
Default jaguar wont start
hi thanks for the reply, but the problem ife got is i cant even get it to turn over nothing is happening when i turn it after ignition point, ive put a different batery on with leads to another car so plenty of power, not checked the air filter but will do that tomorow, do you no were the main earthing strap is as i think ill lean the terminal theere, it can only be something as petty as that shoury and hopefully
Old Jun 14, 2012 | 02:40 PM
JimmyL's Avatar
Do you get any lights on the dash ? Radio work ? The main earth (ground) is from the negative battery post via braided cable to the body in the boot (trunk). There is another one going through the false bulkhead on RH side under hood - there's a stud that goes through the bulkhead (this is power, but very important). There is another under the car behind the RH front tire that goes from bellhousing to frame (I think, but you'll see it). These are all important. I have had a car not get power even while being jumped because of corroded battery cable ends.
JakeJagg11
Sep 3, 2015 07:36 PM
1964Daimler
Sep 2, 2015 11:41 PM
BlacXJRcat
Aug 28, 2015 07:10 AM
Zues
Aug 27, 2015 12:02 AM
divingmom
Aug 25, 2015 07:54 PM
