Jammed starter
Old Jul 22, 2018 | 08:01 AM
Kenf's Avatar
Default Jammed starter
I turned the key on my 2009 XJ6 and there was no sound. I thought the starter was jammed. I returned later and the car started. How do I free the starter if it happens again ?
Old Jul 22, 2018 | 08:28 AM
NBCat's Avatar
Begin by checking battery voltage with the ignition in the OFF position for at least ten minutes. Check voltage across the terminals, which should be a minimum of 12.6 volts. If it's less, charge the battery overnight and test it again. If you still have less than 12.6 volts, the battery must be replaced.
Depending on the number of kilometres/miles on the vehicle, the starter may be failing. Check for voltage at the starter with the key turned to START. If there is no current to the starter solenoid, check the relay and swap with one of similar design. If relay function is normal, check wiring loom.
If the starter is indeed failing, it's best to remove it and have an automotive electrical specialist overhaul it. I have not had much luck with the 'remanufactured' units sold at the various parts houses.
Old Jul 29, 2018 | 11:20 AM
steven300's Avatar
make sure battery is powered up,while someone is working the key;tap or tap harder[ram it] on starter with heavy metal rod.don't worry about damaging the starter as it my be no good anyhow
Old Jul 30, 2018 | 12:26 AM
grantorino62's Avatar
Over the many years I've replaced/rebuilt starters, I always coat the starter bendix gear with lithium grease. Once installed, the grease coats the ring gear in case there's a rough spot on the ring gear teeth. I learned this watching a technician at a Dodge dealership overhauling starters. I never saw a comeback.
Terry Young
Feb 24, 2017 10:46 AM
LnrB
Feb 19, 2017 07:00 PM
Qvhk
Dec 24, 2016 08:42 PM
fergusstrachan
Jan 2, 2009 10:05 AM
XJ40ish
XJ40 ( XJ81 )
Jun 15, 2007 10:56 AM
