Just replaced my tensioner look what I saw (pics)
Old May 12, 2016 | 07:15 PM
maniqz's Avatar
Default Just replaced my tensioner look what I saw (pics)
I just got this XJR last week, it has a August 2001 build and I can't find the engine serial no. So I just decided to but a new metal tensioner thinking it still had the 2nd gen plastic ones and voila! See the first picture, the tensioner is plastic and has crack, trouble waiting to happen. My Jag has 83k miles only. Second pic shows newly installed metal tensioner.
Attached Thumbnails Just replaced my tensioner look what I saw (pics)-image.jpeg
Old May 12, 2016 | 07:23 PM
maniqz's Avatar
For some reasons I can't attach the second pic so I'll just add it here
Old May 12, 2016 | 07:34 PM
King Charles's Avatar
Proper preemptive strike, kudos.
Old May 12, 2016 | 11:36 PM
WaterDragon's Avatar
Good job, none too soon!
Old May 13, 2016 | 02:29 AM
JagV8's Avatar
Good work!
Old May 13, 2016 | 06:16 PM
ericjansen's Avatar
Still strange how different things can be.
Did mine last week, and the plastic tensioners came out without a single crack.
almost 70.000 mls. on them.
Still happy that I did those, it feels much better.
Old May 13, 2016 | 08:47 PM
I'm thinking local climate accounts for a lot.
Old May 14, 2016 | 01:17 AM
Vector's Avatar
2nd gen added the spring, but it only made it rattle less before it failed.
Nice save!
Vector
Old May 14, 2016 | 06:23 AM
Daim's Avatar
Did you place all of them or are you still happy playing engine damage lottery?
Old May 14, 2016 | 10:54 AM
maniqz's Avatar
Nice save!
Vector
And the spring stopped giving us an audible warning of it's impending failure, poor decision on jaguars part.
Old May 14, 2016 | 07:00 PM
ericjansen's Avatar
I thought that the 'rattle' counts for the gen 1 primary ones, that the secondary let go without a warning whatever the generation?
Old May 14, 2016 | 07:18 PM
Vector's Avatar
"Usually"
Gen 1 secondaries "might" give you some warning rattle, 2nd gen? Not so much because of the spring, usually.
All primaries usually rattle before failure, but failure there is not usually catastrophic.
Vector
Old May 18, 2016 | 11:04 PM
maniqz's Avatar
Now here's the passenger side secondary tensioner, see how the plastic has been taken off the metal piece. How the chain has practically sawed the metal part, yet before I opened the valve cover I never heard any metal to metal grind. I have saved a Jaguar from catastrophic failure, feels good to catch this in time.
Old May 18, 2016 | 11:15 PM
harvest14's Avatar
That's a good feeling isn't it? Now you're "hooked" though. Saving Jaguars from extinction will be in your blood from now on....
Old May 19, 2016 | 06:03 AM
Daim's Avatar
Again, don't just do the secondaries. Your chains have worn underneath. They are now less stable and can break... I only ever do the lot or nothing... 4 or 5 times now, without my own V8.
Old May 19, 2016 | 08:00 AM
ericjansen's Avatar
Daim, where do you get your info on breaking chains from?
I read several disastrous cases of jumping or breaking secondary chains over the years, but never on worn primary chains as a cause, just cracking guides.
Old May 19, 2016 | 09:27 AM
Jhartz's Avatar
Now you need to ask "where did that plastic go?"
In the oil pan.
Old May 19, 2016 | 09:32 AM
Eurobahn Jaguar's Avatar
Sponsor
Great catch!
Old May 19, 2016 | 11:55 AM
dsnyder586's Avatar
Lucky the plastic slipper didn't lodge between the exhaust cam gear and chain and snap it- very common.
Old May 19, 2016 | 12:19 PM
Vector's Avatar
4-5 times! In how many miles?
Well I agree that the secondary chains may be worn on the outside of the chain where it touched the metal part of the tensioner, but that has nothing to do with the primaries.
Replace the secondary chains if you want to be safe, but they are probably OK.
Experience has taught us that the primary system lasts a long time and gives plenty of warning before it fails, which is not catastrophic anyway.
Secondaries are an easy DIY, primaries are a big job requiring specialized tools and knowledge.
Vector
