Key in door is killing my windows repeatedly. What is going on?
Old Jun 2, 2025 | 09:39 PM
MWC's Avatar
MWC
Default Key in door is killing my windows repeatedly. What is going on?
The lock cylinder in the driver's door has been deteriorating to the point where I have to sort of wiggle it back and forth to get the key out. A few days ago my driver's side window would no longer go down. I also noticed my sunroof would close automatically after a few seconds.
After searching this forum I found that others had a similar problem and solved it by draining down the electrical system thereby resetting some module that controls the windows. I confirmed that this worked on my car, but as soon as I locked it again the window stopped working again. This is infuriating lol.
I would use the fob, but my memory seats are not working right and the seat assumes an insane position every time the car is unlocked with the fob.
Does anyone know how I can make the windows stop getting confused by the lock cylinder?
Old Jun 3, 2025 | 11:28 AM
Vauxi's Avatar
Take the lock cylinder apart. Clean it and put it back together with thin grease. Wiggling the key may mess up the bcm.
Old Jun 3, 2025 | 12:07 PM
Jhartz's Avatar
Maybe a quick shot of WD 40 or equivalent in the lock and a hard reset of the battery.
Old Jun 9, 2025 | 11:29 AM
hispeed42's Avatar
The windows are controlled by the door modules which are on the SCP (Standard Corporate Protocol) network. The seat memory is somewhere in there, too, but I haven't figured out exactly where the the settings are stored. I changed out the driver's seat module a few years ago thinking that I would be able to reset the memory, but the seat keeps going to the original setting, so it's not stored there. Maybe some of the electrictronical gurus can chime in (?)
I attached the electrical guide for your enjoyment.
Mark
File Type: pdf
Old Jun 9, 2025 | 12:04 PM
RandyS's Avatar
You can disconnect the electrics to the seat so that they will not
auto adjust when you unlock the car. That would assume, of course,
that you would be it's only driver.
jindra
Aug 24, 2024 08:50 AM
Ftype R 2017
Feb 11, 2022 08:13 PM
Bcrary3
Mar 6, 2020 06:21 PM
danielsand
Sep 15, 2013 10:42 AM
jsmolin
XJ40 ( XJ81 )
Dec 14, 2010 01:04 PM
