Lamp-high Mo
Old Mar 19, 2022 | 09:08 AM
DougXK8's Avatar
Default Lamp-high Mo
Assistance needed please. I have a problem with my rear Lamp-high Mo (that's how it's described) Jaguar Part No: LNC5000AFAGD.
It has come adrift from the rear window and I initially tried superglue to stick it back to the window. Fell off after a few months. Then tried araldite but again failed to stick it on for any period of time. Can anyone suggest anything else. Or is it likely that something is missing/broken off the light fitting - see photo's.
Old Mar 19, 2022 | 09:43 AM
motorcarman's Avatar
Jaguar refers to that as HMSL. (High Mounted Stop Lamp)
A glass company uses adhesives made for glass. They use the same type to remount rearview mirrors to a windscreen.
Jaguar issued a TSB years ago but products change over the years.
File Type: pdf
File Type: pdf
Old Mar 19, 2022 | 10:49 AM
Addicted2boost's Avatar
I second the glass company recommendation.
Old Mar 19, 2022 | 02:17 PM
Parker 7's Avatar
Preparation of the glass is critical
You may have to use a razor to remove the old adhesive on the glass and sandpaper on the housing glue material left over
Old Mar 20, 2022 | 03:51 AM
DougXK8's Avatar
OK thanks all, I am going to try 2mm thick 3M VHB tape first, which I believe they use for rear view mirrors. The indications are that it has temperatures resistance for along time 93° Celsius. In short time 150° Celsius.120 degrees. If not successful will try glass glue.
Unhingd
Apr 11, 2022 08:06 AM
Terry007
Sep 7, 2021 05:33 AM
semorex
Jun 12, 2020 08:47 AM
MarkyUK
Aug 23, 2019 10:39 PM
peterv8
Jun 29, 2019 11:00 AM
