Low brake fluid indicator
When I am decelerating hard and really press on the brake pedal, I get a "low brake fluid" warning, despite the fact that the my fluid is topped off. Brake pads and rotors were last checked 9 months ago. What has gone spongy and is causing that fault indicator?
Please clarify: has the pedal gone spongy? If so there is air in the lines. But that should not cause the low fluid message.
There is a float in the fluid reservoir, and it sometime sticks or actually sinks. If you use the search function you will find some threads that address this problem.
aholbro1
Dec 29, 2024 06:46 PM
Richard_gib
Sep 12, 2015 07:08 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
