Low coolant message
I just changed the thermostat and flushed the cooling system and I get a low coolant message? No visible leaks or odors, coolant reservoir is full.
Any ideas before I change the sensor? Temp gauge just over half.
Thanks in advance.
Thanks in advance.
The float (sensor) in the coolant expansion tank is stuck.
Use a large plastic spoon or something similiar to stir the coolant in the tank (located in the near the rear part of the engine compartment - driver's side).
I had the same thing happen to me after our indy mechanic replaced our coolant. It seems to be a common occurance.
Look post# 4 in the following thread:
https://www.jaguarforums.com/forum/x...d=2#post881946
Also this thread:
https://www.jaguarforums.com/forum/x...t-light-19717/
Jim Lombardi
Also this thread:
Jim Lombardi
Also this thread:
Jim Lombardi
Also this thread:
Jim Lombardi
