Low Coolant Warning
Old Aug 23, 2016 | 06:43 AM
Muhammad Umer's Avatar
Default Low Coolant Warning
Hi,
i got a low coolant warning after switching to S mode on my Jaguar XJR supercharged, and the warning went away after i switched back to normal mode, could it be related to the supercharge or its just the coolant is low, please advice.
Regards
Attached Thumbnails Low Coolant Warning-img_5558.jpg   Low Coolant Warning-img_5562.jpg
Old Aug 23, 2016 | 06:48 AM
jimbov8's Avatar
It won't be related to the supercharger. Check your coolant tank, very carefully check all the coolant hoses and check the sensor in the coolant tank.
Old Aug 23, 2016 | 06:58 AM
Thanks Jim, i just checked the coolant tank and it was about half, i refilled it, im gonna try the supercharge at night, since it very hot outside, the temp is about 35 Celsius, im being careful, dont wanna break anything.
Old Aug 23, 2016 | 07:08 AM
jimbov8's Avatar
The supercharger is running all the time the engine is. The sport button just lengthens the time on gear shifts.
You have a leak somewhere on the coolant system.
Old Aug 23, 2016 | 04:54 PM
Refilled it, no more low coolant warning. thanks Jim for the support.
Old Aug 23, 2016 | 05:01 PM
ericjansen's Avatar
Probably not related to the button selector, but you might have brought more heat in during some spirited driving.
As mentioned, it can be several things, and might take a bit of observing time to find.
Can be just too low level, a leak, the reservoir cap, the thermostat, or a warning of something to come ...
Just be very careful not to overheat the engine, the instrument gauge in NO indication of what is really going on.
It will stay in the middle most of the time, only to shoot up once it is almost too late.
On a side-note, THAT is a beautiful car, don't see many with a body kit around.
Old Aug 25, 2016 | 03:32 PM
Thanks Eric, i will definitely be careful with this car, waiting for winter to come, cant really push the car to it's limits in this weather here.
Old Aug 31, 2016 | 08:52 PM
Lear45's Avatar
The low coolant level comes on at 1/2 tank. Not much of a leak and you will see it.
Carry a gallon of water in the trunk. It serves many purposes. If the car breaks down
for whatever reason, it is nice to have while you walk to civilization or await rescue.
It is handy if the reservoir is a little low. If you have to keep adding water every month, then you need to find and fix the leak though
Old Sep 1, 2016 | 08:09 AM
Thanks Lear, i filled the tank and no more low pressure warning.
klfong
Apr 7, 2016 05:51 PM
jamesackerman
Apr 4, 2016 03:47 PM
vincent661983
Apr 2, 2016 12:59 PM
DanielSWE
Mar 28, 2016 06:22 AM
warekito
Aug 9, 2007 10:02 AM
