Lower pulley came off a 2nd time.
Old Apr 3, 2014 | 01:28 AM
WaterDragon's Avatar
Default Lower pulley came off a 2nd time.
This time I am going to use some lock tight red on the threads.
I am going to go ahead and install a new lower stock crank pulley, new cone and bolt, with some red thread lock and hope for the best.
Old Apr 4, 2014 | 12:36 PM
Update,
new lower stock pulley installed with lock tight on threads (apparently the more recent pulleys come with lock tight from Jag)
Mechanic also sealed a little around the locking ring.
Seems to have worked as the end of the super charger pulley is rock solid (zero wobble) when the engine is running, which is a big relief.
Now my car is officially done. Everything is now updated. upper and lower tensioners, abs solder, new rotors, brakes, tires, all new hoses under the hood. Rebuilt Gen5 blower (ported), new pluges, oil/filter. Should be good to go for quite some time Now I'm going to stop messing with it. It has stock upper and lower pulleys and is going to stay that way.
Old Apr 4, 2014 | 02:41 PM
Dan Hiatt's Avatar
Glad to hear the pulley issue may be resolved. Awesome that you have so many niggly issues already resolved.
Now, about you leaving it alone....
Old Apr 4, 2014 | 03:02 PM
Brutal's Avatar
one of the reasons its recommended to use a new bolt each time
Old Apr 4, 2014 | 04:19 PM
Yes, Used a new bolt and cone this time. We think the cone was scuffed and was not contacting well...
mrplow58
Jan 21, 2024 05:53 AM
PMKimpton
Aug 3, 2019 08:22 PM
Johncy2000
Dec 22, 2017 04:32 PM
auburn2
Dec 29, 2015 06:31 AM
sonofdave1980
Sep 14, 2015 07:45 PM
