Lower pulley threads
Old Apr 29, 2012 | 10:07 AM
barny's Avatar
Default Lower pulley threads
I need to remove the crank pulley on my 99 XJR and thought i'd have a go at making my own pulley removal tool. What I need to know is what size are the threads in the pulley where the removal tool attaches.
Old Apr 29, 2012 | 10:30 AM
adam699's Avatar
I'm not sure, but that sucker is on there tight. I stripped both of them when removing it so have a tap and bigger size bolts on standby.
Old Apr 29, 2012 | 07:10 PM
motorcarman's Avatar
The bolts need to be 8 X 1.25mm
I would suggest a high grade bolt.
bob gauff
File Type: pdf
Old May 2, 2012 | 01:51 AM
barny's Avatar
Thanks I'll get a couple and try them they looked smaller the M8
bob gauff
Old May 2, 2012 | 05:05 AM
Sean B's Avatar
use only the M8 high tensile cap heads, a la Jaguar tool, why not just buy the correct thing, it's £45, see here
SPX Catalog - V8 Petrol
You cannot get the crank pulley if you damage it by the way....
mrplow58
Jan 21, 2024 05:53 AM
Johncy2000
Dec 22, 2017 04:32 PM
GordoCatCar
Jan 2, 2017 01:10 PM
auburn2
Dec 29, 2015 06:31 AM
DustysSon
Sep 13, 2015 04:17 AM
