Lube / Grease Points
Old Jul 16, 2016 | 06:12 PM
l3uddha's Avatar
Question Lube / Grease Points
Can someone tell me where all the serviceable lube / grease points are on the x308? And is wheel bearing grease OK for all the grease points? Thanks
Old Jul 16, 2016 | 07:44 PM
RJ237's Avatar
The only grease fittings are on the half shaft universals, two per side. I suppose bearing grease is fine but I usually use a grease gun with lithium cartridges.
Old Jul 18, 2016 | 11:29 AM
Mark SF's Avatar
Some of the aftermarket front lower balljoints have grease nipples, though I wouldn't recommend putting too much grease in as you'll just force the dust covers off.
Series1fan
Jun 24, 2016 09:23 PM
Wayne'sJaguar
May 25, 2016 07:11 AM
bullittandy
May 8, 2016 11:15 AM
Johnmart0000
May 3, 2016 09:08 AM
Pierrick584
Apr 29, 2016 09:44 AM
