Lug nuts 1999 XJR where to buy ?
Old May 23, 2019 | 10:17 AM
MrTeaser's Avatar
Default Lug nuts 1999 XJR where to buy ?
Anyone know where i can get a set of new lug nuts for my 1999 XJR, The chrome caps are swollen and make getting sockets off a pain. Look like picture, found picture it on ebay but they only have 8 and the price is out of the world I can not afford $600 for a set of 20 lug nuts. If there was an aftermarket design I would consider it to.
Old May 23, 2019 | 10:29 AM
yeldogt's Avatar
Have never found any exact replacements .... e-bay is your friend. So you need all of them?
It's one of those items you have to point out ... warn and inform that care must be used when removing. Most shops never encounter -- so they are rough when removing. The dent as well.
Old May 23, 2019 | 11:04 AM
Carnival Kid's Avatar
I think this is the part number for your vehicle/lug nut type?
Jagbits has them for $8.79, not cheap, but you could get a set for around $175.00
https://xks.com/i-6920342-jaguar-lon...a-ccc7029.html
And even better, MotorcarsLTD has them for $6.71, so $135 bucks a set
https://www.motorcarsltd.com/ccc7029.html
Old May 23, 2019 | 11:18 AM
jagbits's Avatar
Former Sponsor
That picture of a CCC7029 is the long shaft nut, it's highly unlikely the correct one on your XJR can you post a picture of one from your car?
Old May 23, 2019 | 11:44 AM
dwgates's Avatar
Default lug nuts...
I too am too cheap to replace the whole set for my 99 XJR so I picked up a handful from SNG to replace the worst on mine.
I was having trouble with a few of the caps but also had trouble with a few of the washers falling off at the base.
This past weekend I was doing the brakes on my daughter's Toyota Solara (Camry variant) and noticed they use something that looks very similar even down to the external hex size (with the cap).
I'm wondering now if they would actually fit our cars.
I'd expect that Toyota lug nuts are reasonable...and a lot more common than ours.
I'll have to see if one of my spare Jag bolts fits her car to double check, unless someone knows something that would short cut this process for me (us).
Old May 23, 2019 | 01:10 PM
motorcarman's Avatar
The Jaguar wheel studs for that era car will be 1/2" x 20 TPI (NOT Metric).
bob
Old May 23, 2019 | 08:59 PM
M. Stojanovic's Avatar
I bought a set of CCC7029# (OEM) from DMG (David Manners) at £3.75 a piece.
MikeofBonsall
Jun 29, 2017 12:19 PM
EyeDoc
Oct 30, 2013 10:51 AM
Mark Scotton
Jun 9, 2012 03:47 PM
christer200
Jul 31, 2009 09:27 PM
