Manual adjustment of steering column
Old May 10, 2012 | 02:11 PM
Bollotti's Avatar
Default Manual adjustment of steering column
I have a 1998 model Daimler V8. I have issues with the steering column.
It will move up and down okay, but the reach does not work. I was given the replacement part when I bought the car to amend this.
This is not the main issue, when I have the wheel set to its maximum height via the motor, it still looks like there is room for another couple of inches movement upward.
I am assuming that this may be due to the reach not working.
The steering wheel is a tight squeeze when getting in and out of the car, which also leads me to think that the column will move higher.
Is there a way of disconnecting the motors and adjusting the column to be permanently in the correct (comfortable) position?
Thanks in advance.
Old May 10, 2012 | 05:41 PM
Sean B's Avatar
it's a simple job to swap the motors out and have a working adjustment both ways, it's nice when it works. Typically under an hour to do so maybe contact a Jag specialist in your area, if your round my way I'd do it.
There isn't a way of manually adjusting a power column short of stripping it and the motors.
Welcome to the forum.
Old May 11, 2012 | 03:46 AM
Bollotti's Avatar
Thanks for the reply. I will look into this, as I think there is a local specialist in the Scottish Borders.
Old May 11, 2012 | 06:19 AM
hflavell's Avatar
Currently the reach on my steering column is non functioning as well. When I get the time I will replace the part, but in the mean time I am able to push/pull in and out manually on the steering column to adjust the position.
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
PMKimpton
Aug 3, 2019 08:22 PM
Richard_gib
Sep 12, 2015 07:08 PM
jagent
Sep 12, 2015 09:10 AM
