Misfiring on cylinders 1 and 4, codes p1316 and p1111
Old Jul 12, 2012 | 10:31 AM
princemarko's Avatar
Default Misfiring on cylinders 1 and 4, codes p1316 and p1111
Pulled over, gassed up ... started the car and here we go again with the Check Engine light flashing, Restricted performance and these error codes... Any one have an idea?
I did have a K&N air filter which i suspect is being a pain in the ***... Hope thats it...
Old Jul 13, 2012 | 05:27 AM
Sean B's Avatar
I'd check for oil in the plug wells, this would cause a misfire and then it's engine management that put it into failsafe because of exceeded misfires, it protects the cats this way.
Other than this, what fuel did you fill up with and how old are the plugs?
Maybe swap the coils round if no oil is found on 1 and 4. See if the misfires follow the swap, then it's a case of getting a couple of coils.
Jagged-X
Sep 24, 2015 05:08 PM
tsimms7
Sep 15, 2015 12:43 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
Bcrary3
Sep 11, 2015 10:36 AM
corysansburn
Sep 10, 2015 06:15 AM
