multiple fault codes, wont start
Old Aug 5, 2014 | 07:08 AM
frankslawn's Avatar
I am having the identical problem...son borrowed car, spun out, hit a curb, broke passenger rear knuckle and wheel...now the car is in failsafe mode and will not even crank....
where is the inertia switch located and how is it reset??? thanks
Old Aug 5, 2014 | 08:17 AM
RonaldP's Avatar
Just a short note when checking the battery voltage. Put the positive lead on the battery post with a good hard push, then check voltage at three spots with the negative lead. 1) negative battery post, 2) negative lead at the post so you read through the connection for a high resistance corroded battery post, 3) a good body ground. That will help rule out the battery charge and connections. You can also do the positive post the same way, with #3 test at the bus bar.
Old Aug 5, 2014 | 10:11 AM
avt007's Avatar
Go to the electrical troubleshooting link in my signature, it has a slide on the inertia switch. Basically it's in the passenger footwell, in the very right front corner. There's a big black rubber button on the top.
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
