My Radio id dead.
Old Jan 2, 2023 | 02:22 PM
etachu's Avatar
Default My Radio id dead.
I have been away for some time. Happy new year folks.
My radio appears to be dead or maybe the fuse is blown. Does not come on when I push the button. Wondering to solve this problem.
Old Jan 2, 2023 | 02:40 PM
Ken Cantor's Avatar
Does it come on if you press one of the mode selection buttons (ie tape, CD, AM/FM)?
Old Jan 2, 2023 | 02:53 PM
etachu's Avatar
No, it doesn't come. Whatever button I press I get no response.
Old Jan 2, 2023 | 04:11 PM
Ken Cantor's Avatar
If it’s a fuse there are two:
#9 (10 amp) in the left hand side heelboard box which is located behind the carpet cover in between the rear seat and floor; and
#3 (5 amp) in the fuse box in the trunk.
If you’re not sure where those are, the PDF shows the location of all of your fuse boxes.
Hopefully this helps…
Old Jan 2, 2023 | 05:08 PM
etachu's Avatar
Thanks for this. Will check it out.
Old Jan 3, 2023 | 10:44 AM
Parker 7's Avatar
The on / off button is an encoder like on the earlier X300 Jaguar / Alpine AJ9500A control head and that sometimes can be replaced
there are 2 different versions of the control head between the years of X308 production
the early years are more like the x300 version
Your year may be the crossover point
On the VDP you probably have the premium setup using the round cable ( problem area ) from the head to feed an amplifier in the trunk with it's own fuse
You can feel for the amplifier getting warm by feeling it as it has a form of internal protection leaving the fuse not blown
Do you get any display of tuning frequency in the head ?
Old Jan 3, 2023 | 11:42 AM
RandyS's Avatar
Complete lack of power in the head unit sounds very much like a toasted fuse. If that proves
not to be the case, then check your grounding.
Old Jan 4, 2023 | 02:07 PM
etachu's Avatar
Folks, thanks for all your responses. The issue is fixed. Just by pressing down the fuses and relays in the truck fuse box. Seems some fuses were loose.
Old Jan 4, 2023 | 03:49 PM
RandyS's Avatar
Loose fuses can confuse you...true
John L
Feb 21, 2018 02:16 PM
tmurena
Oct 9, 2017 12:11 AM
93xjs6cyl
Apr 27, 2017 10:41 PM
Capper
Jul 7, 2016 07:57 PM
Jamey
Oct 24, 2009 01:50 PM
