need front wheel bearings...
Old 11-02-2012, 10:54 PM
coastaljag98's Avatar
Default need front wheel bearings...
I need wheel bearings for my 98 XJ8. ANyone have recommendations on which one I should get that is affordable and decent. Any part numbers?
Thanks.
Old 11-03-2012, 07:43 AM
ixj8it's Avatar
timken, also if the inner bearing race has spun on your hub, you will need to replace the hub. If you dont, the wheel bearing will be going out again VERY soon.
Old 11-03-2012, 09:16 AM
Received 7,900 Likes on 4,772 Posts
If you have the original 1998 vertical links then you need the 76mm diameter bearings.
For example:
SKF Part # FW115
Timkin, *** or other name brand bearings will fit.
bob gauff
Old 11-03-2012, 11:42 AM
Thanks justs ordered from Napa store. 44 bucks. I believe my hubs are all original as this guy never replaced anything on this car when it went out. Car runs great just needs a lil TLC and paint job but want the mechanicals right first, then tires. So getting rid of the vibration and howling is gonna be an improvement!
hunter34
19
09-14-2022 11:09 PM
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
dsnyder586
04-04-2019 02:38 PM
Whitnessmouse
09-04-2015 11:09 AM
Quick Reply: need front wheel bearings...
