Need help wire colors 98XJ8 interior mirror.
Old Feb 28, 2014 | 12:57 AM
Fyrplg's Avatar
Default Need help wire colors 98XJ8 interior mirror.
Going to replace interior mirror with light sensing mirror other than stock, as it is dark all the time and rear window is tinted and hard to see out rear window.
I need the wire colors for the light sensor that turns on headlights when dark out.
My lights only work in the auto position and come on and stay on when the sensor is covered. (something in steering light switch)?
Does the wires from the sensor close or open with darkness? I will have to bypass the sensor so lights will come on. I have another mirror without the sensor and hope somebody can help with the wire colors to the sensor.
Thanks.
Old Feb 28, 2014 | 08:40 AM
motorcarman's Avatar
Why not just repair the wiring in the multifunction column switch??????????????
Usually a wire becomes broken/disconnected at a solder lug terminal on the switch.
bob gauff
Old Mar 1, 2014 | 01:23 PM
Fyrplg's Avatar
Thanks Motorcarman.
Sorry But I am not able to doe the Work on the wiring, Just to old and have a heart problem that wont let me do things like that anymore.
The reason for an after market mirror is it is not tinted in the daytime.
Thanks for tip. wish I could fix.
Do you have any Info on the wiring colors?
H20boy
Dec 24, 2024 03:23 PM
hoodun
Sep 14, 2015 01:26 PM
1964Daimler
Sep 9, 2015 11:28 AM
danpop
XJ40 ( XJ81 )
Sep 8, 2015 03:23 PM
jaguarbill
Sep 5, 2015 11:43 AM
