Need parts / advice for 2000 XJ8
Old Sep 19, 2011 | 02:37 PM
george82's Avatar
Cool Need parts / advice for 2000 XJ8
Hello friends!
My 2000 XJ8 won't start. A local mechanic told me that the alternator, battery, and brake pads/brake rotors all need to be replaced. It's a right-hand drive by the way.
Could you please share some advice, about getting either used parts from someone else in the forum, or a recommended trustworthy website for ordering all of the above?
Thank you so much!
Old Sep 19, 2011 | 03:57 PM
Brutal's Avatar
Check rockauto.com, or partsgeek.com both good n cheap. Alternator???? Really!!! Theyre pretty expensive cause they rarely fail. I would go more battery, bulkhead fitting in engine compartment, and or ground strap(engine to chassis)
Old Sep 20, 2011 | 04:00 AM
Cadillac's Avatar
Yuo can try our vendors , since you're a forum member you can also get some discount
www.gaudinjaguarparts.com
NALLEY JAGUAR
Other sources
www.jagbits.com
www.motorcarsltd.com
www.autoanything.com
Old Sep 29, 2011 | 12:17 PM
george82's Avatar
thank you very much!
I found five different alternators in rockauto.com, does anyone have any suggestion as to which model to choose?
Old Sep 29, 2011 | 08:09 PM
jimlombardi's Avatar
Hi
I found another forum thread where the Alternator parts were found and used to rebuild it:
https://www.jaguarforums.com/forum/x...ild-fyi-58290/
The reason I thought to research the parts available for X308 (XJ) was that I have had the good fortune to be able to replace the brushes in the alternator for our 1990 Acura Legend.
The snap-in set of brushes are available at our local Acura dealership.
It does sound like the Jaguar is as easy as the Acura alternator fix.
Jim Lombardi
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
hafren
Sep 2, 2015 06:22 PM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
